Brief Description: Fuel line isolation foam blocks
Make fuel line isolation foam blocks. Cut out two 2"x6"x7/8" blocks of styrofoam. Mark the location of the fuel and break lines and drill two 1/4" holes and one 1/2" hole as shown on the pictures (1/4" for break lines, 1/2" for fuel line). The holes are drilled in the 2" direction of the foam block. Since the fuel lines are already installed I had to cut the foam blocks in half and install one half under, the other half above the lines then wrap the hole assembly with stiky aluminum tape. This created a very firm isolation block and very light.
