Make short aluminum fuel line from the Facet Fuel Pump. This was necessary since the flexible fuel line cannot be bent at such a short tight angle as required by the configuration of the Facet Electric Fuel Pump. From here I will use the fexible line to the Fuel Selector Valve (Andair). This was very time consuming since I had to bend sevaral tight angles to connect to the Fuel Pump. After fitting the flexible braided fuel line to the Fuel Selector Valve it looks I vasted 2 hours making the left short aluminum line. As it turns out the flexible line can be bent to reach the Selector Valve.
