Make short aluminum fuel line from the left input to the fuel selector valve to past the lower snap bushing on the F-983B-L Cover Support Rib. This was necessary since the flexible fuel line cannot be bent at such a short tight angle as required by the configuration of the Andair Fuel Valve. From here I will use the fexible line to the wing using a union to connect to the flexible line. This was very time consuming since I had to bend sevaral tight angles to connect to the fuel valve connector. The third attempt worked. The rest of the fuel system will use flexible lines.
