Brief Description: Install F-989 elevator push-rod
Fit F-989 elevator push-rod into QB fuselage. Since all the bulkheads are installed it was very difficult to put this push-rod in place. The threaded rod ends hung up on the bulkheads. Install F-635 bellcrank. This is very tight space so I first installed the F-3514M rod end bearing on the F-635 bellcrank. Once the bellcrank is put in place it would be near impossible to install the rod end bearing. After the bellcrank installation the threaded rod end at the end of the push rod can be easily screwed into the rod end bearing.
