Clamp in place the F-6118 rudder pedal brace and the F-6115 center rudder pedal bearing block. Check allignment of the assembly. Match drill firewall stiffener with rudder pedal brace (through holes drilled in rudder pedal brace). Cleco in place. Check allignment as the rudder pedal assembly moved back and forth. Mark the holes for the three adjustment positions for the rudder pedal in the flange of the rudder pedal brace. Fit everything into the fuselage.
