Brief Description: Landing light installation right wing
Using the Template A supplied with the installation kit mark the lens hole and the six platenut holes on the wing. Cut-out the hole with Dremmel tool cutting disk. Deburr and sand hole egde. Trim approx. 1" from the longest end of the light mount. Deburr and sand all the mounting assembly parts. Match drill the plate nut holes with the retainer strips on the wing skin using the pre-marked spots. Using Template B mark the two locations (A&B) on both ribs.
