Install 3/8 OD polyethylene tube for pitot heat wire. This conduit fit nicely into pre-drilled holes except in the last two ribs where the line had to be moved closer to the top if the wing skin. Drilled two 1/2" holes and moved the gromets. This will allow for a clean wiring installation.
