Fabricate small aluminum angle to hold and steady aluminum pitot line to wing rib. This also acts as a heat sink before the poly-flow line is attached. Drill, deburr and dimple hold down bracket and install on rib. Fabricate tiedown for plastic pitot line (poly-flow). Make aluminum pitot and and install connectors.
