Worked on the dimmer unit installation. Had to remove the switch panel to drill the 1/4" hole for the potentiometer plus two #38 holes for locking in the pot from rotating. Touch up the switch panel with black paint. Twist the power wire and install according to plans. Re-install all switches and plugs plus the pot. Re-install switch panel.
