The voice command from the AOA computer becomes very low in volume if I turn on the SL30 and GMA 340 units together. Previously, based on instructions, I attached he audio wire to the tip of he pilots audio head phone jack. This will not work. Move this wive to the Alt Wrn In pin (31) on the GMA 340 . This was very time consuming job, because I had to re-route the audio wire. The test now worked fine. Looks good. Worked on the GTX330 daa entry option.
