Brief Description: Wiring for GTX330 Update connector
After an all morning session and abortive attempt to install the 9 pin Sub-D connector on the panel, I decided that the simple and most effective solution is to tie the connector on the right side of the fuselage well. This connector is used only for GTX330 software update. It is easily accessible at this location and used infrequently (see picture). Pull speaker wire under the panel on the right side for easy access for later speaker installation.
