Brief Description: Bottom cowl air intake baffle seal
I worked on the bottom cowl air intake baffle seals as shown out in the plan. Originally, I planned to use plate nuts to install the seals, but I realized it would take too much extra drilling so decided to use #6 screws, bolts and countersunk washers. Drilling and counter sinking the fiberglass took more than I expected. To install the lower cowl is not easy and I wanted to give myself an easy out if I found that the seals create more difficulties.
