John B.s Web Site
Date:  10-19-2013
Number of Hours:  2.75
Brief Description:  Work on main gear leg fairing
After transferring the template from the drafting paper copy to the gear leg fairings I cut the fairings to final size using the hacksaw. Although time consuming to achieve accuracy it went pretty easy. The fiberglass is quite thin for this part. Sand the cut edges and fit on the gear legs.
Fuse921
Fuse921
