Work on the lower hole for the attach bracket on the right side. This I was able to do from the inside of the fuselage. I prepared a small wooden block predilled on the drill press for vertical guidance. Because the F-996-C reinforcement angle has a slight deviation the hole is slightly off from vertical. This was also a multi step drilling process.
