Brief Description: Position/Strobe Lights, Fuel Tank Attach Bracket
Decided to recheck the rear position/strobe light; connected the power, re-measured all power values and tried to orient the strobe device both vertically and horizontally. The reason is that Aircraft Spruce sells two versions of this device; one for vertical and the other for horizontal orientation. Mine is the vertical as came from VANS. No change; the device didn't work as I thought, but in desperation try anything. Have to wait for the new strobes to arrive. Work on the T-905R Fuel Tank Attach Bracket. Measure the mounting hole locations (2) DWG 38. I have marked these earlier, but decided to re-check to be sure. They sure look OK. Will drill and fit them tomorrow.
