Take off the fairing from the empennage and sand the two areas that were epoxyed. Drill all the screw holes that will be used to fasten the fairing to the empennage as per plan 44. Add some PolyFiber Filler to smooth out some inperfections. This means a bit more sanding tomorrow. The fit really looks good now. Drill the attach holes on the bracket and the panel frame that will hold the music input jack.
