Research the previous day's problem with the elevators. Checked out the vansairforce site to see what other builder experienced. What I found out is that it is not that uncommon and most considered this amount (11/32") exceptable. Went out to the hangar to check if there is any twist in the elevator structures, but found none. Also the trailing edges are as staright as an arrow. Will call VANS tomorrow.
