Steves Web Site
Date:  12-15-2009
Brief Description:  Reinstall muffler bracket, radiator hose
I noticed when I installed the braces for the muffler, I left out the bushing that goes inside the rubber grommet out. So I disassembled each piece, inserted the bushing, and reassembled the assembly.
I also cut down the length of the bottom radiator hose, As designed, it was too long and required routing the hose on top of the battery to take up the extra length. I cut off 2" on the small end (lower radiator side) so now it goes VFR direct from the themostat to the lower radiator.
Super Trapps installed with braces
