I installed the passenger side door. Trying to figure out the correct 'centering' procedure was not easy. The instructions are vague and until you are ready to install the rudder gasket around the door, everything is subject to change.
The door handles had alot of surface rust on them but the steel brush cleaned them up.
Installing the door handles was not well documented. The cylinder need to be install in a particulare orientation but the instruction were silent on that point. The bolt that the door handle uses must be tailored somehow to hold the door tight. I'll figure that out later.
I was short to nylon nuts for the window. The factory packaging of these parts was odd in the sense that I expected hardware for the Left and Right Doors, bujt in several cases some parts were combined. When putting the doors together, one did not know if he was stealing from one side to complete the other side.
