Dan, Justin, Jordan, and I cut the HS in half and installed the end cap ribs into both halves. I cut line of the HS becomes the outboard side of the tail feathers. However, I discovered Nick had glued the HS spar off center 1/4" at one end, which when it is flipped over next to the VS, shows a mismatch of 1/2" on the left side leading edge and the right side leading edge.
I'm sure this will not effect flight, but I maybe able to minimalize the appearance.
