I took the lastest version of the drawings to Staples for printing. Only .17 cent for each 11"x 17" sheet.
I reassembled the drawing s and discarded the obsolete versions.
Since I ordered a new turnbuckle, I need to cut off the nicopress fitting without harming the rubber cables. Using the dremmel tool with a cutoff blade, I was able to cut the fitting without nicking the steel cables.
