Brief Description: Reinstall lower sprocket and prop
Dan and I mounted the prop onto the lower sprocket which was not currently installed itself. It sure made tighting the bolts easiler. Then we put anti-seize on the bolts and mounted the lower sprocket and tightend the 'mule shoe' to torque spec. Dan then safety wired the bolts.
Dan also remounted the Super Trapp mufflers onto the exhaust pipe after having the mufflers spot welded to prevent bolts from going through the prop.
