Steves Web Site
Date:  10-11-2009
Brief Description:  Set 12 degrees on prop
Built the two special tools.
The first was the paddle to set the pitch on the prop.
The second was a "Z" shape 9/16" wrench for holding the nuts to the prop hub.
I used a cheap wrench and with the help of blow torch and hammer, I was able to create a perfect wrench for the job.
Set 12 degrees on prop.
