Installed the trim box using a couple of longer bolts than needed just to keep the progress going. There is a slight interference with the rotor brake but replacing the bolts with the proper size will resolve the issue.
Brian and I nicopress the cables and hung the springs. I not sure of the purpose of the chains on the springs. The written directions says 5 links but every picture show 3. I choice 3. On the passenger side, I cut on of the links out to tighten up the slack in the cable tension.
