I adjusted the placement of the Flight Leve 760 radio between the GX2 and the Garman transponder and cut the hole with a hole saw. The outcome was slightly larger than I wanted to still looks good. Next I cut the panel for the RPM display. Finally, I cut the hole for the ignition switch. This hole has flat sides to prevent the switch from rotating. I drill two holes overlapping and filed the sides flat.
