Spent hours trying to discover information about the EJ25 in the kit and if I had a interference engine and it I needed to replace the timing belt.
Dan Bank told me that it was from a Legency, Forrester, or Imprez 2001-2003. He believes it is not a interference engine I said GBA replaced the spark plugs, filter, and timing belt for the customers.
He agreed that adding a PCV value would be a good idea and to leave the port on the heads open to the atmosphere.
I discovered I'm missing the pilot side support bracket for the PSRU bearing. Dan will try to send one to me.
My engine had a tag on it. "EJ25 SOHC 9294.001" Serial # B457108 Head 795342/795425 Block 18 BA | BB 18 33333 |
