I had two different engine rod supports that bolts to the top of the PSRU. One only had two bolt holes that ran top down and the other had two bolt holes that ran top down and two that would bolt horizontally into the PSRU. I assume the later was for the EJ25 and it require we remove the PSRU again and drill matching holes.
