The new steel alternator bracket modification to the alt mount has been painted and installed. The Autolite 13322 alternator has been adjusted and mounted.
Sanded the tail feathers some.
Drilled holes on the cross on the keel to hold the horizonal engine support rods. There was no description I could find to tell where to place these brackets. Dan suggested we make them equal distance as the PSRU is. So we carefully layed that out. However, I drilled 3/8" holes instead of 1/2". I purchased additional bolts from Aircraft Spruce to cover my mistake.
