I discovered during a pre-engine run up that there was no oil pressure wire coming out of the engine harness (green with white stripe). However, in the cabin that wire was present and I have installed it to the GX2 interface.
So solve the problem, I ran a seperate wire from the oil pressure sensor to the GX2 interface.
