Brief Description: Continuing with the Overhead Switch Panel
Continuing with the Overhead Switch Panel, I made the following connections: Memory Fuse to ECU Ground to Frame connection for the ground block in the Overhead. Glued 3 more cable tie holders to organize the overhead cables.
