Brief Description: Fab cable for Transponder to Encoder
Fabricated a cable to connect the Garmin GTX 320A transponder to the TRANS-CAL ALTITUDE ENCODER MODEL SSD120-30N-RS232 using a 10 conductor cable.
The Garmin has a tray with the cables attached making it easy to remove the transponder without unpluging the cables. However, the backshell I used on the 25 pin connector is too bulky to attach to the tray. I will need to locate a metal backshell that is thinner.
