I began to wire the position/strobe lights and thought the hole through the cabin's fiberglass my fray the electrical wires, so I removed the lights and drilled a larger hole and reinstalled the lights. Then I cut 1/4" clear plastic tube to fill the hole and used clear silicon to fix it into place.
I soldered the 5 conductor cable to the position/strobe light and heat strunk everything. I ran the cable to the strobe box and solderedt the pins to the leads (and crimped them also).
I prepared the ground leads with terminals and grounded the lead and the metal box. I relocated the strobe box to the left side of the cabin board to make room for more cables.
