SVEN-AKE'S WEB SITE
Date:  4-19-2014
Manual Reference:  chapt 7
Brief Description:  aileron cables
Removed upper skin and primer, after sanding and deburring. Mounted aileron cables, and locked with safety pins.Spent some time to figure out where to connect fuel return line into tank. I need to install a fuel drain valve in each tank, but space is limited. It is Easter saturday and I have to wait until tuesday to order parts.
Yesterday I recive an answer from ICP about angles Y6-W-11-52, they should be attached to front rib no 3 and 4 as I thought.
2 angles 6-W-11-52
2 angles 6-W-11-52
installed
installed
