I recived a 50mm longer propellerhub today, together with tools for dismantling. A good extractor made it easy to remove the old one. After cleaning the new installed with Loctite on threads, and torqued to 240Nm. Backplate for spinner and propeller fitted. Check again, and adjust propellerangle to19,8 deg. Torqued to 28Nm according to spec. Nordlock under bolt-head and Nyloc nuts on engine side.
