SVEN-AKE'S WEB SITE
Date:  9-3-2015
Number of Hours:  3.00
Manual Reference:  Kit 2&3
Brief Description:  oilcontainer
An AL 6061-T6 plate, 1mm, was cut to fit on rightt side of engine mount. Outer edges are bent 45 degrees, to stiff up plate.
Than attached with 4 cushioned clamps (19mm) around steeltubes. Oil tank and the fuel filter bolted on inner side. Voltage-regulator attached to outer side. AWG 10 wire to ground and battery.
12 M6 screws with washers and locknuts.
