SVEN-AKE'S WEB SITE
Date:  9-2-2015
Number of Hours:  3.00
Manual Reference:  Kit 2&3
Brief Description:  install ECU
An AL 6061-T6 plate, 1mm, was cut to fit on left side of engine mount. Outer edges are bent 45 degrees, to stiff up plate.
Than attached with 4 cushioned clamps (19mm) around steeltubes. ECU and the two ingnition-coils bolted on side.
8 M6 screws with washers and locknuts.
4 M5 screws with washers and locknuts.
