Brief Description: new airfilter and cooling performance
To get cold air to engine, I fabricated a auminium channel. Placed between mufflers, with a smaller air filter inside. A 90 degree silicone hose direct air to inlet manifold. To make a test I once again got out on rwy, for lowspeed taxi at approx 30 minutes. Results: Inlet air was below 25 deg. at whole test. OAT was 18 degrees. Coolant temp stabilized to 87C, after 30 minutes. Oiltemp 93C.
