In order to get more airflow through radiator I fabricated a quick & dirty solution. At rear end of cowling, a small aluminium spoiler added. Pointing 45 degrees down. An aluminium frame direct air to radiator. All other openings were closed. A ground test indicates better flow, but intake air got a very high temperature. Up to 50 C. Indicates need for a separate air-filter channel.
