An AL 6061-T6 plate, 1mm, was cut to fit on rightt side of engine mount. Outer edges are bent 45 degrees, to stiff up plate. Than attached with 4 cushioned clamps (19mm) around steeltubes. Oil tank and the fuel filter bolted on inner side. Voltage-regulator attached to outer side. AWG 10 wire to ground and battery. 12 M6 screws with washers and locknuts.
