An AL 6061-T6 plate, 1mm, was cut to fit on left side of engine mount. Outer edges are bent 45 degrees, to stiff up plate. Than attached with 4 cushioned clamps (19mm) around steeltubes. ECU and the two ingnition-coils bolted on side. 8 M6 screws with washers and locknuts. 4 M5 screws with washers and locknuts.
