The same procedure as on right wheel. On left side I started with the two rim halves separatly, grind them carefully to make them slip on easy. Than installed tire, tube and bearings on axleshaft. I will replace the 3 stainless steel bolts with standard 8.8 quality M8x70 . Threads on stainless steel bolts do not meet my requirements, unless they are silver plated.
