Found this 2/3 HP Craftsman 6" Disc / 4" X 36" Belt Sander on Craigslist from a seller that lives between work and home. Work surface has mitered pivot to 45 degrees. The only problem I found was that the work surface did not mount perpendicular to belt sander due to improper hole indexing of the retaining bolt holes to the single flat surface on the mount rod. This was easily corrected by grinding in a couple of new flats on the opposite side of the rod that were offset by about 5 degrees.
