Sonnys CH650
Date:  3-30-2014
Number of Hours:  0.20
Manual Reference:  NA
Brief Description:  Drilled Hole Off Location
While attempting to hold the outboard flap rib in position and match drill through the pre-drilled skin holes the rib slid out of position by about 2mm resulting in the hole shown in Image 1.
Fabricated a new rib and this time instead of clamping and holding it in place I aligned the front flange centerline through the skin holes and marked the hole location through the hole with a fine Sharpie. Removed the rib, center punched in the center of the dot, drilled to 3/32" then re-inserted and clecoed to the skin. Repeted this on the remainder of the ribs with excellent results. Much easier to control hole location with confidence using this method.
Hole off location
Hole off location
