Sonnys CH650
Date:  11-13-2011
Number of Hours:  2.40
Manual Reference:  6T3-B pp 1-4
Brief Description:  Top Elevator Horn
Layed out holes then pilot drilled doubler 6T3-6.
Drilled two holes in web for attachment of angle 6T3-7. Trimmed corner off of angle to clear top skin then - as precisely as possible - drilled two holes in the angle flange to match the web holes. Clecod in place; hole spacing and location were good.
Layed out and pilot drilled holes in top horn 6T3-4. Located horn against a straight edge clamped on the center line and match drilled the 3 center holes. While drilling the 1st aft hole the straight edge unknowingly had slipped just a bit causing the hole location to be about a hole width to the left. Will either 1) drill two new holes - one on either side of original or 2) adhere a backing strip (skin doubler of sorts) to the skin so I can use the original hole in the horn. Waiting for response from Caleb.
Locating Angle Holes
Attaching Angle
Attaching Angle
Horn and Doubler
Horn and Doubler
