Sonnys CH650
Date:  1-14-2014
Number of Hours:  1.80
Manual Reference:  Dwg 6AT01
Brief Description:  Completed Left Aileron
Cut 1/4" off of hinge pin
Drilled holes in each end of hinge for safety wire
Safety wired both ends of hinge to prevent pin from walking out
Riveted trim tab together
Did not prime mating surfaces on skin.
Clecod all components together using every other hole
Inserted and pulled rivets on top then bottom
Had to use hand puller for 2 rivets next to balance arm
Another very light but rigid subassmbly complete.
Need to store these in the basement then move on to flaps
Complete
Complete
Trim Tab
Trim Tab
Manual Riveting
Manual Riveting
