Sonnys CH650
Zodiac CH650
Dwg 6W12
Clarification from Zenith
Received response from Caleb:
All three balance arm hole locations should be measured from the rib flange
The balance arm angle should be set at 97 (not 94) degrees to ensure the weights wont hit the top wing skin.
Will use this information in my next build session
Hole Locations
Zodiac CH650 Home
545
Ailerons Flaps
51
103
267
Materials
MISC
Mistakes/Deviations
Research & Planning
Services
Tools & Jigs
Work Area
