Last night I emailed a DWG file of wing rib #1 to Blueprints Plus here in Houston as a first option for creating templates for the wing rib form blocks. Plot came out great but at $39.51 I think I'll just hand-draw the rest of them when the time comes.
Rounded corners on elevator servo access cover. Ready to pilot drill.
Since completing all of the elevator parts I've been trying to figure out how to assemble the horn suppport to the bracket inside the elevator. The solution turns out to be simple and should have been obvious; simply rivet the support and bracket together then raise the top skin to insert the sub-assembly through the bottom skin then close the top. Duh!
