Brief Description: Nose Rib Drawing Coordinate Revision
After hand-drawing the 6T4-1 rudder rib form block profle I noticed that the points at (62.5, 29.7) and (62.5, - 29.7) did not fall on a best-fit curve with the other points. I called in a favor with a friend back in Michigan who I worked with at Chrysler to lay out these coordinates in Catia which yielded the same results, confirming that I hadn't lost my 8th grade drafting skills! I sent a PDF of the Catia layout to ZAC tech support for their review. Caleb promply replied with a revision of drawing 6-T-4 dated 03/11 on which he actually revised two coordinates (3rd and 5th).
