Sonnys CH650
Zodiac CH650
More Brake Work
Deepened the seven countersinks in the base plate to accommodate the larger #12 flat head screws. Drilled seven attach holes in work bench. Finished priming the bottom and bending plates. Primed top plate. Drilled holes in grab handle. Almost done!
Zodiac CH650 Home
545
Ailerons Flaps
51
103
267
Materials
MISC
Mistakes/Deviations
Research & Planning
Services
Tools & Jigs
Work Area
