Brief Description: aileron hinge brackets and flap brace assembly
Match drilled the aileron hinge brackets in and outboard left wing, match drilled flap brace at the same time.The wood brace photo one is aligning the outboard aileron hinge bracket. This was frustrating because the hinge bracket at tip was leaning in slightly, so I decided to add a little pressure prior to match drilling, worked a trea.
